12498543 Graphite Gasket vs 12498544 Metal Gasket
I was wondering if I can use my MLS gaskets that I put on for a dyno run. I removed the heads to degree the cam and want to use the same gaskets. they have at least 500 miles. I have a pair of graphite gaskets on stand by, but I want to use the MLS ones if I can. what do you guys think?
within a few hundred miles, and assuming they are still good, yes they can be reused.
But at 29.99 the pair, I'd just buy a new set...
Last thing you want is coolant in your oil
