Piston too valve clearnce? cam motion 236/250 .612/.612 114+4 lsa
Old 05-28-2012, 04:22 AM
Brandon331's Avatar
Default Piston too valve clearnce? cam motion 236/250 .612/.612 114+4 lsa
I have a cam motion nitrous cam that is a 236/250 .612/.612 114+4 lsa and I was wondering if I was going to have any piston too valve clearance issues with this cam?
Old 05-28-2012, 04:29 AM
PREDATOR-Z's Avatar
On intake no, but I would measure exhaust.
Old 05-28-2012, 01:08 PM
Brandon331's Avatar
Any one ever run this cam on a stock long block?
Old 05-28-2012, 04:05 PM
badazz81z28's Avatar
Brandon,
This question is asked 2 or 3 times a day and NOBODY will give you a yes or no no matter how small the cam is. Everyone will tell you to measure.
Old 05-28-2012, 09:12 PM
LSX Mechanic
Damian's Avatar
Brandon,
You will more than likely have clearance issues on the exhaust side. From what I've experienced, mid 240's is about the highest in duration you can get away with on an unmilled head before things get too close for comfort. But then again, I've measured some mid 230's cams that needed flycutting.
I would absolutely positively NOT install that cam without checking PTV clearance. It will more than likely not clear. A checker spring and dial indicator is in order here.
Old 05-28-2012, 11:48 PM
Brandon331's Avatar
Originally Posted by Damian
Brandon,
how much would ya charge me too put it in tune it and all..ive been trying too get ahold off ya .
Quick Reply: Piston too valve clearnce? cam motion 236/250 .612/.612 114+4 lsa
