Weights of LS Blocks
Old 04-01-2013, 03:38 PM
  #41
kacivic's Avatar
LT1Altered: If you're still interested in the weight of the carb'd LS intake manifold, I've got an Edelbrock Performer RPM manifold I can weigh for you tonight.
Old 04-01-2013, 04:16 PM
  #42
LT1Altered's Avatar
That would be great.
I also have more data from some other parts I've weighed so I can update the chart.
Since converting my car from carbureted LT1 to EFI LS1 I lost a total of 45 pounds.
Old 04-04-2013, 06:36 PM
  #43
kacivic's Avatar
My shipping scale reads 15 lb 2.4 oz for the bare ls1 Edelbrock performer manifold.
Old 07-29-2013, 05:49 AM
  #44
Back in the staging lane
Beeler422's Avatar
Originally Posted by bww3588
Tubular k member and some weight reduction on the front end will easily make up that 110 lbs.
The logic here is flawed. You can have those same weight reduction mods with a lighter block. So it is still costing you 110lbs.
Old 07-30-2013, 09:02 AM
  #45
Justhereforinfo's Avatar
Originally Posted by JohnFrazee02SS
good info but a 5.3/4.8 block?
Anyone?
Old 08-22-2013, 05:03 PM
  #46
99427camaro's Avatar
any one ever took the weight of a ls1 with darton sleeves
Old 08-24-2013, 07:58 AM
  #47
drkjyost's Avatar
Having a 408 iron block built now LQ9; will just boost my way past the extra weight. Going to 15 lbs first.
Old 08-25-2013, 09:29 PM
  #48
hotstreet's Avatar
Sometime a little weight is worth it~
Old 08-26-2013, 09:19 AM
  #49
thunderstruck507's Avatar
Don't know how I've never seen this thread but it's a nice wake up call for all the people on tech who keep spouting off the weight difference is LESS than 80lbs between ls1 and lq4/lq9. It's actually a bit more.
Old 08-27-2013, 09:59 AM
  #50
lsdart's Avatar
Interesting.....
Old 09-18-2013, 11:04 PM
  #51
NW Iowa WS6's Avatar
The hard part to swallow about this weight is its front end, where weightloss is most important, if it was in the rear I wouldn't mind a bit but looking into future strokers this makes an LS2/3 worth the money maybe. I don't want my 60' taking a **** at the already less than impressive track prep my local track has.
Old 10-24-2013, 04:14 PM
  #52
OkieDave's Avatar
its hard for me to think that the iron LS block is about the same weight as a BBF block.
Old 02-23-2014, 08:46 AM
  #53
bmeyer40's Avatar
Thanks good info
Old 05-26-2014, 10:00 PM
  #54
3stgstocker's Avatar
So does anybody have an accurate weight for a 6.0 iron block alum head motor complete less power steering and ac compressor? I'd like to know just busted a alum block cracked around the motor mount bolts but it las test 5 years! Thinkn about going to steel block for durability and better ring seal and hopefully not to crack it around motor mount bolts!
Old 08-18-2014, 12:48 PM
  #55
xx_ED_xx's Avatar
Why not just run a engine plate and keep using the alum block
Old 09-13-2014, 05:40 PM
  #56
ericwilloughby's Avatar
Originally Posted by Mighty Whitey
Iron 6.0, $150
Ls2 block, $500
Try dropping 110lbs for $350!
Where are you getting blocks that cheap. I just gave $350 to have a crack welded and sleeve put in an LS1. Cheapest I can find an iron 6.0 is $1200 complete, $700 long block with iron heads and LS2 is $1200 bare.
I'll give $800 for a bare LS2 right now. Who wants my money?
The following users liked this post:
Blac94z28 (12-10-2019)
Old 01-29-2015, 01:33 PM
  #57
white01ss's Avatar
Default Lsa
Curious what the weight of a LSA block is. Can we add that to the list?
Old 03-07-2015, 12:07 PM
  #58
Tuskyz28's Avatar
I want to know myself. Old post but bump.....
Old 04-11-2015, 12:02 PM
  #59
jcb5565's Avatar
Thumbs up
Weight on the front end can be reduced to help compensate for the added weight of the iron block. Putting the battery to the back can save around 40 lbs and help with traction. Changing out some front end parts can save you another 10 - 20 lbs. I'm putting a Dart LS iron next block in my C5, the block weighs 227 lbs. and can handle high boost. The oiling system has been redesigned to give you better oiling than the LS1 blocks. Personally the oiling system and added strength sold me on the Dart block.
Old 04-19-2015, 12:53 AM
  #60
Tuskyz28's Avatar
I finally got the scoop!! A 5.3 aluminum block with Darton sleeves weigh 105 lbs. The block is setup for 4.125 bore or bigger!!
Quick Reply: Weights of LS Blocks
