Choosing springs for mystery cam
3811R/3798R HR114+2
DURATION @ .050 INTAKE 225 ROCKER ARM RATIO
DURATION @ .050 EXHAUST 223 INTAKE 1.70
LOBE LIFT INTAKE .3360
VALVE LIFT INTAKE .571
LOBE LIFT EXHAUST .3320
VALVE LIFT EXHAUST .564
LOBE SEPARATION 114.0
Will a 918 or similar beehive work for this?
LS1Tech Premium Sponsor
What heads are you running, or more importantly what valves? Also what rockers?
With a GM valve and rocker on the combo, a PAC 1218 spring would do nicely!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Cool, PAC 1218's should work very well, and you could shim them a bit for some added pressure with those solid valves!
__________________
