6.0L mild build what to buy
Old 06-19-2012, 10:08 PM
cartel's Avatar
Default 6.0L mild build what to buy
was thinking of alum heads - i just emailed AI to see what the timeline is for a set. as the Trick Flow Specialties TFS-3061T001-C02 - Trick Flow® GenX® 225 Cylinder Heads for GM LS2 are $12oo each cost
mild cam-
new rings-bearings-oilpump-
Arp bolts..
are the rods fine to reuse?
i have a holley pan retrofit already --
what else should i replace?
Old 06-20-2012, 05:23 AM
mark21742's Avatar
I'd replace the rod bolts while your in there with a set of ARP or Katech bolts, and look at a low to mid 230's cam.
Also pick up an ls2 chain and ported ls6, or melling oil pump
Old 06-20-2012, 05:40 PM
Paul57's Avatar
What are you calling "mild"?? What kind of power are you looking for??
Old 06-23-2012, 09:45 PM
cartel's Avatar
450 would do me fine--
i see ARP bolts rods-- are $150
where are katechs sold? not at summit? not at ws6..
Old 06-23-2012, 10:32 PM
Turd Gen Guy
1nasty86's Avatar
Set of ported 243's, 235/242 lsl/lxl cam, fast 102 and supporting drivetrain mods... Make 450 no problem
Old 06-24-2012, 12:07 PM
cartel's Avatar
i hadnt thought of what intake yet-- was just going to get a ls6 type but maybe i should upgrade intake and new injectors..
Quick Reply: 6.0L mild build what to buy
