One mod just creates another mod needed
Old 07-08-2012, 03:03 AM
smahlum_21's Avatar
Default One mod just creates another mod needed
I have purchased a lot of new parts for my 99 TA. Your welcome TSP. Got their stg 2.5 ls6 heads with torquer v3, 1 7/8 headers, Fast 92 TB, Ported fast 92 intake along with other minor things. Just started taking parts off the car to be ready for new parts when they get here. I bought a used set of red top fuel injectors and am now wondering if i will NEED a new fuel pump or will my stock ok? Seems like I keep buying more and more needed parts to supplement my head/cam purchase.
Old 07-08-2012, 03:30 AM
The Scammer Hammer
dr_whigham's Avatar
197 bucks to ward off an engine DEVASTATING lean condition seems like a no brainer to me..... Racetronix with the hot wire kit.
Old 07-08-2012, 03:51 AM
mark21742's Avatar
Do a quick search for the 265 lph DP65c.....they have a stait drop in kit for $150
Old 07-08-2012, 10:58 AM
smahlum_21's Avatar
Didn't find anything when I googled that except a pump that says a direct fit for Hondas and acuras
Old 07-08-2012, 01:28 PM
TransamGCS's Avatar
unfortunately thats part of the game a mod is no good without the supporting mods. red top i assume those are 30lbs injectors. your stock pump will probably keep up but your duty cycle is probably going to be maxed out which could cause a lean condition later on down the road. you might want to think about going to at least 36 lb injectors or 42 lbs and i would upgrade the fuel pump to a racetronix with hot wire kit. not worth the risk of going lean
Old 07-08-2012, 03:15 PM
smahlum_21's Avatar
I bought the red top being told those are 36lbs on a ls1, is that incorrect? I did take the plunge and buy a racetronix today
Old 07-08-2012, 03:35 PM
moeZ28's Avatar
Red tops are 30 lbs injectors on most other vehicles fuel pressure...on an LS fbody, they are around 36 lbs because our cars run higher fuel pressure at 55psi I believe.
Old 07-08-2012, 10:32 PM
The Scammer Hammer
dr_whigham's Avatar
LS1 fuel pressure is 58 with a good pump. Your red tops are 36's. No worries there, unless you plan on a shot of nitrous.
Congrats on the racetronix. You won't be disappointed.
