Porting the Fast 102 intake?
Old 07-09-2012, 08:54 AM
dferg99's Avatar
Default Porting the Fast 102 intake?
How many horses are you guys gaining after porting a Fast 102, lets say on a 408 cu set up?
Old 07-09-2012, 08:58 AM
WS.666's Avatar
Sub'd
Old 07-09-2012, 09:01 AM
Avaric3's Avatar
id imagine the numbers will vary due to cam, heads and exhaust setups involved
Old 07-09-2012, 10:08 AM
BrianSF-GA's Avatar
... yep, cam, heads, exhaust & cubes.
I have been watching posts of 102's both ported & unported and their results thinking I may want to step up, but I have only seen minimal rwhp increases and, in some instances, reduced rwt numbers. As far as I am concerned, I am sticking with my Vengeance ported FAST 90 and 497 ft-lbs. of rwt!
What have others experienced?
Any track results before and after?
Old 07-09-2012, 12:37 PM
Blk98Vert's Avatar
^^If you increased your entire intake tract to 100mm you would see substansial double digit gains. OP if you had it fully ported on a 408 you are looking at double digit gains vs putting it on out of the box
Old 07-09-2012, 01:10 PM
dferg99's Avatar
That sounds very interesting. I have the 104 lid, 100 maf, thru the 102 nitrous express plate feeding the 102 fast. So you think porting the Fast with what I already have will give good results.
Quick Reply: Porting the Fast 102 intake?
