Valve spring Identification Help
Old 07-10-2012, 12:56 AM
LS1axle's Avatar
Default Valve spring Identification Help
I bought some heads on ebay but the seller could not tell me what kind of springs are on them so Im going to swap them out but I would like to use the retainers and locks. I need to know what springs would be compatible with these retainers and locks?
Thanks
Attached Thumbnails Valve spring Identification Help-valve-spring-1.jpg   Valve spring Identification Help-valve-spring-2.jpg
Old 07-10-2012, 09:02 AM
TurboBuick6's Avatar
You need to pull a retainer off and take the measurements of the steps for anyone to properly get you into a spring that will work.
Old 07-10-2012, 12:36 PM
Brian Tooley Racing's Avatar
Dual springs with a dampner in between? You don't see those too often on hydraulic roller LS heads.
Yes, measure the steps like was mentioned above and let us know.
Old 07-10-2012, 05:01 PM
LS1axle's Avatar
Ok will do thanks for ur help
Quick Reply: Valve spring Identification Help
