ls1 knock sensor question
ok i have a 2000 camaro with the ls1 in it but im puttin a lq9 408 in it and someone told me the sensors were diffferent. i also have the harness from an 03 truck and didnt know if i could use that also.
LS1 knock sensors are 1 wire and the LS2 knock sensors are 2 wire and on the side of the block, and will not work with a LS1 ECM, I don't know about the other engines you mentioned.
