oil pump ???
You can port You're oil pump and shim the pressure relief valve spring and be just as good as the LS6 ported oil pump ,,,,,,or You can get a brand new Melling 295 for $60 at Amazon ,,,,,,,,,all factory GM LS oil pumps experience pressure drop above 6500rpm's .
