EL Torro vs. TSP 228r
Old 07-22-2012, 10:02 PM
DigOnlySS's Avatar
Default EL Torro vs. TSP 228r
I wanted to see how these two cams compared to one another. I will be looking at a cam here in the near future and these two seem to be what I am looking for. The car is mostly a street car with your occasional trip to the track. I am looking for a nice streetable cam that I wont regret on wishing I had gone bigger. I'd like to have power all throughout the power band with some down low grunt as well. The motor on the car includes:
99 Camaro SS M6
-Fast Toys 98mm LID
-Ported Throttle Body
-ls6 intake manifold
-TSP 1 7/8 Long tube headers
-TSP true duals
-4.10 gears (stock 10 bolt)
-stock heads and bottom end
Both cam specs:
EL toro cam (by predator-z)
230/230 .615/.592 111+2 LSA
TSP 228r
228/228 .588"/.588" 112 LSA
The camaro is my daily driver at the moment so keep that in mind. Just looking for some insight and would rather do as much research as possible before making a final decision.
Old 07-23-2012, 09:36 AM
HVYMTL's Avatar
I've been debating on the el torro-ish cam for a while too. Do a search on 'reverse split' cams, pred-z and Pat g have done some really interesting threads on the concept. Since essentially that is what the el torro cam is (even though the durations look the same with 230/230). Maybe that will help you decide? I think chris1313 used one for a while too... The difference I would think there would be between the two is that the el torro cam may have a flatter/broader torque curve, but I'm certainly not an expert
Old 07-23-2012, 11:44 PM
DigOnlySS's Avatar
Appreciate it HVYMTL , It seems like the reverse split cams carry there power band more in the low to midrange. I wonder how this will effect my 4.10 gearing and if it will be too much wheel spin?
Old 07-24-2012, 12:14 AM
99Bluz28's Avatar
IMO, a 228/228 111lsa would be a better would be option then the 112lsa, but still more streetable then the 230/230 111+2 lsa.
Either one would be nice!
Old 07-24-2012, 08:38 AM
Camaroking1996's Avatar
Chrs1313 went 10's in a reverse split cam only car. They make awesome numbers. I would go with the El Torro because it gives more potential for future mods..
Old 07-24-2012, 10:54 AM
TXZ28LS1's Avatar
Both those cams will be streetable and easy to drive.
BTW, i ran a reverse split in my 02 fbody, and liked it. I would run that cam up against any cam.
Old 07-24-2012, 01:29 PM
PREDATOR-Z's Avatar
El Toro potential:
Old 07-24-2012, 02:07 PM
DigOnlySS's Avatar
Originally Posted by PREDATOR-Z
El Toro potential:
Very impressive, is this on a stock cube ls1 motor im assuming with heads/cam?
Old 07-24-2012, 02:26 PM
PREDATOR-Z's Avatar
Yes, stock bottom LS1, heads, cam and 90/90 FAST M6 Corvette.
Old 07-24-2012, 02:47 PM
c0ncEpT's Avatar
IMO the El Torro is very close to that perfect size between to large and leaving some on the table for a street car.
It has great manners and is easily tuned with no surge or bucking. Plus it makes great power and has run the number to back it up.
Old 07-24-2012, 09:12 PM
DigOnlySS's Avatar
What type of gearing would be ideal for the reverse split styled cam such as the "el toro?" Would 4.10's be too much allowing for too much wheel spin?
Old 07-24-2012, 10:40 PM
Camaro99SS's Avatar
I have 4.10's and with my combo 1st gear is useless. I can spin my Michelin Pilot 285's all the way through 2nd and smack the rev limiter on any form of blacktop, hot or cold. My numbers are from a known conservative dyno, but I can run right with procharged 3V Mustangs from a 2nd gear roll.
I'm going down to 3.73's when I get a new rear as I don't want to have to run drag radials all the time on the street.
Jason
Old 07-24-2012, 10:47 PM
[QUOTE=PREDATOR-
What kind of lobes do you usually use on the El Torro?
Old 07-25-2012, 12:07 AM
FRiCK's Avatar
The 230/230 111+2 makes SICK tq. Hands down the best cam for a street/track car. I've won some races I shouldn't have because of its tq curve...
And if I had to choose a gear for this cam it'd be 3.73's.
Old 07-25-2012, 03:52 AM
PREDATOR-Z's Avatar
My grind is on XFI intake and XER exhaust.
These are the specs at .050
Compcam lobes:
Intake lobe # 3016R
Exhaust lobe # 3725R
111 LSA
109 ICL
Old 07-25-2012, 09:31 PM
irocurpony8489's Avatar
Compcam lobes:
Intake lobe # 3016R
111 LSA
109 ICL
can you get your cam through texas speed when i was looking at cams i couldnt find anybody that sold your cam so i settled for the 228r. Now im thinking since my car is my weekend toy that i should go with the el toro. my goal is 11.5's cam only.
Old 07-25-2012, 11:57 PM
intenseblue's Avatar
Not gonna be worth four-five tenths. Be lucky if the difference is worth one tenth. 3.73 gear will go farther and make the car more fun for the money. If you're gonna go through the trouble to swap cams you might wanna go a little bit larger than two degrees duration and four degrees of overlap.
Old 07-27-2012, 03:51 PM
the car has the stock cam still 228r hasnt been installed yet.
Old 07-27-2012, 04:16 PM
Ryans99ls1's Avatar
love my el torro. awesome street cam
Old 07-28-2012, 01:01 PM
Fbodyjunkie06's Avatar
If anyone wants the "El Torro" grind they will have to be custom ground.
If you want this cam I can have it ground as we are a dealer for comp and I spec custom cams all the time.
Quick Reply: EL Torro vs. TSP 228r
