Lq4 Teardown and swap into 99 T/A
Old 07-23-2012, 12:06 AM
greenvortec97's Avatar
Default Lq4 Teardown and swap into 99 T/A
got a A4 Trans Am with 148k miles, tuned by an idiot, with lid, slp maf (i will be going speed density soon) ls6 intake, 36#'s and pacesetter longtubes Lca's and panhard bar, car is supposed to be around 330rwhp as it sits.
picked up an 89k mile lq4 that i will be dropping in the car soon. Im pulling the heads off the lq4 tomorrow
now for the questions..
i'm planning to be over 400RWHP and a decent amount of torque.
does anyone have any proven setups of cam/milled 317's?
I'm PLANNING on ordering an ss3600 or a circle D counterpart since they are local to me. if anyone has some track numbers and proven setups let me know.
Old 07-23-2012, 04:37 AM
usnfenix's Avatar
curious....the lq4 and 317 setup has lower compression and is typically used for superchargers and turbos. if your goals are for a N/A build then no offense but an lq4 with 317's isnt going to be the best route IMO. 400rwhp is very easily attainable. a ls1 with mild cam and stage 2.5 ls6 heads will make over 400rwhp.
Old 07-23-2012, 06:19 AM
Redbull87's Avatar
You can make good power with the lq4 still n/a.just have to pay more attention to the combo of parts.My cam only lq4 with ls6 intake is making 352rwhp and 360tq on stock exhaust.There are many guys running lq4s without doing much making over 400rwhp.
The 317's are good heads just large cc,mill them down to bump compression and port/polish with a decent cam in the 230 range with the rest of your mods would make good hp and very strong tq under the curve.A set of 243 heads for higher compression would further improve results.
You can make over 400hp with an ls1 easy too but it wont be as torquey as a built lq4/9 down low.Or through a stroker kit in it more cubes..more torque.
Old 07-23-2012, 07:30 AM
Turd Gen Guy
1nasty86's Avatar
Id say take your 317's and sell them, get a set of 243/799 heads and mill them to 62cc which is a .020 mill and throw them on, get a decent size cam like a 230/236 112+2, use the ls6 intake for now but a fast would be worth 20 tire hp and got with circle d on the converter
Old 07-23-2012, 12:52 PM
randywyatt2000's Avatar
if youre goin tobe useing the lq4 with a 4inch bore just go with some ls3 heads and a good camshaft
Quick Reply: Lq4 Teardown and swap into 99 T/A
