Just bought a set the steel HD rocker arm stands, for LS6 build, the stands are threaded, I thought they should be just clearance holes like the factory stands. Is this right?
So do your rocker bolts thread down through them ok?
I have those, All you have to do it's rotate them till they connect (thread) to the heads, they fit fine with the stock rocker bolts and even better with the Comp Cams trunion upgrade.
