ls1/ls2 pushrods....are they the same length?
Old 08-08-2012, 01:13 AM
moge11's Avatar
Default ls1/ls2 pushrods....are they the same length?
are ls1 and ls2 pushrods the same??? my brother bent one in his trickflow cammed 6.0 thats in his 98 trans am today... a buddy has some ls2 pushrods... just wondering before we waste the gas and his time to dig them out.... thanks for any help in advance......morgan
Old 08-08-2012, 02:21 AM
bww3588's Avatar
I wouldn't use stock push rods in an engine with a cam and stiff springs. It will surely bend before you know it.
Trick flow will sell you a single push rod. Ask me how I know.
Old 08-08-2012, 02:24 AM
moge11's Avatar
i know right... found out that they are all 7.4... i just new the ls6 cam had a small base circle and was curious about the ls2 as well.. but its the valves that are different lengths, not the pushrods... but its a temporary fix for now.. car was bought this way and bought CHEAP/partial trade...
Old 08-08-2012, 03:34 AM
PREDATOR-Z's Avatar
Temporary or not, that is the wrong fix. For starter aftermarket 7.400 pushrods are not the same length as stock OEM pushrods. Stockers are a bit shorter 7.38x. As mentioned above, stockers will flex too much and could result in further damage to the engine.
Old 08-08-2012, 04:03 AM
bww3588's Avatar
It really needs to be very temporary...like don't run it if you don't have to.
Quick Reply: ls1/ls2 pushrods....are they the same length?
