New cam, big lift, spring pressures?
Just received my custom cam today. Im not sure what springs to use or if the ones I have will be ok. I have the PRC dual springs that came on my PRC LS6 heads. They have a seat pressure of 145# and are max lift .650
My minimum spring pressure needs to be 150-155#.
My max valve lift is .651
Should I use these springs with the cam or upgrade to something with more seat pressure? I noticed some springs offered by Brian Tooley that I might go with. Any suggestions?
