LQ4 Build - Cams and Heads
I have an LQ4 out of an Express one I am swapping into my Legacy. My goal is to get it up around 400 whp. I am looking to put some L92/LS3 head on the LQ4 block. The block is out of an 03 and has the dished pistons. I am not sure what cam choice will be best but the car will be a weekend cruiser with occasional autocross and drag strip fun.
I would like recommendations for a cam and springs that will work well with this combo where I do not have to cut of valve reliefs in the pistons
The motor is coming together very nicely now. Just need to pick up injectors and a few other odds and ends
LQ4 6.0L Block
L92 Rectangle Port Heads
LS3 Blue Springs and Retainers
Comp XR273HR Camshaft (220/224 .530/.534 112LSA)
Billet Timing Chain Kit
Melling OEM Oil Pump
GTO Front Sump Oil Pan and Pickup
L76 Intake Manifold
LS7 Fuel Rail
LS3 Corvette Water Pump
LS3 Corvette Harmonic Balancer
LQ4 6.0L Block
L76 Intake Manifold
LS7 Fuel Rail
