Ls pistons and rod question!!
Old 08-24-2012, 05:54 PM
lstransam's Avatar
Default Ls pistons and rod question!!
Hey guys have a questions to ask. I understand that they are press fit design but once they are taken apart are they reusable.
i know that 5.7 and 6.0 rods and stroke are the same,but just to say could i take the 5.7 rods and put the 6.0 pistons on them.just for example
thanks
Old 08-24-2012, 06:59 PM
chrisfrost's Avatar
Yes You can interchange the rods from the 5.3L , the 5.7L and the 6.0L as long as they are from the same gen ,,,,,,,,,full-floating rods will not work on pistons that were semi-floating pins . Oh ya and as long as The rods were not overheated in the disassembly process .
Old 08-25-2012, 06:26 AM
bww3588's Avatar
You don't heat rods during disassembley...
Old 08-25-2012, 03:35 PM
chrisfrost's Avatar
That's the way I've seen it done (on chevy gen 1's) and have done it Myself ,,,,,,,,,,so how do You get the pin out ,,,,,,I guess on a press and You could cool the pin ?
Old 08-25-2012, 08:03 PM
bww3588's Avatar
Press it out, heat it up to put it in.
