Information on what LS Series block I truly have!
2002 Camaro Z28, 5.7L with the 241 Cylinder heads and LS6 Intake manifold. Did this year come with the LS6 block as well, and what kind of differences are present between the LS6 block and LS1 block if any. Thanks guys.
there is a 25% chance you have a ls6 block i think the only difference is the ls6 block has better crank case venting at high rpm but i think the ls1 block is suppose to be stronger either way the difference is not enough to brag about and which ever block you have is just as good as the other one
Alright, I was just curious about it, I'm the second owner of the car and the lady that had it before me bought all the bells and whistles and I never knew the Z28 came with SLP parts from the factory. I don't know much about the car but thanks for the information.
