What do i need ? LY6 block into ls1
Old 09-23-2012, 01:57 AM
Johnv's Avatar
Default What do i need ? LY6 block into ls1
Picked up a new cast block off a mate, turns out its a LY6 block
What do i need that i can't re-use from my LS1 engine to make this work ?
I will be useing the callies 4" crank from my 383 and buying forged pistons and rods.
as far as i can tell i'll need -
LS2 valley plate
Ls2 front cover with cam sensor
cam sensor harness extention
LS2 timing chain set
ls2 knock sensors
knock sensor harness extenion
ARP head studs (same length)
have i missed anything ?
Old 09-23-2012, 01:58 PM
RQSGTO's Avatar
Hi Mate!
I'm building an LY6 for my 04 GTO, I was told to not use the Ls2 knock sensors. Instead relocate the Ls1 knock sensors to the Ls2 knock sensor location.
If I can think of anything else I will let you know.
Good Luck!
Old 09-23-2012, 02:20 PM
Johnv's Avatar
Originally Posted by RQSGTO
Hi Mate!
Good Luck!
cool that saves a few $$$
Do they bolt straight in or do we need to drill out and retap to suit the LS1 sensors ?
Old 09-24-2012, 06:48 PM
RQSGTO's Avatar
We need to drill and tap.
Old 09-26-2012, 04:53 AM
Johnv's Avatar
Ls2 lifter trays are required as well, ls1 trays won't fit apparently.
Quick Reply: What do i need ? LY6 block into ls1
