Need some help from the cam/head guru's
Old 09-24-2012, 04:03 PM
RNation0001's Avatar
Default Need some help from the cam/head guru's
can someone tell me how much i can mill stock 241 heads before i have to fly cut the pistons?? the cam card is attached below. my goal is to not to have to flycut and wanna keep it safe
Attached Thumbnails Need some help from the cam/head guru's-aicamcard_zps4fb94031.jpg
Old 09-24-2012, 05:27 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
That seems like a pretty sizable cam to me, I am not sure that I would recommend milling the heads more then a clean up mill to be safe on piston to valve clearance. If you are trying to get extra compression I would seriously think about fly cutting and then milling the heads.
Old 09-24-2012, 06:42 PM
Thannks that's kinda what I figured.
Old 09-30-2012, 12:43 AM
can someone break this down for me to the normal lobe seperation numbers
Quick Reply: Need some help from the cam/head guru's
