Head gasket bore diameter?
Old 09-26-2012, 02:28 PM
64post's Avatar
Default Head gasket bore diameter?
It seems a little bit too close to the edge...a 3.910 headgasket bore on an engine with a 3.905 cylinder bore. Anyone ever do this? is it ok? It's only .005 total and .0025 away from being in the cylinder. Some have told me yes, it's ok, some question it. MLS by the way, not composite.
Old 09-26-2012, 03:08 PM
mark21742's Avatar
What heads? That is close, but should work...I like the gasket to be a little bigger than that
Old 09-26-2012, 03:12 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
It works well! We sell a lot of the Cometic 3.910" gaskets for our 347's and 383 assemblies with 3.903-3.905" bore!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 09-27-2012, 12:22 AM
machinistone's Avatar
It depends upon how large of a chamfer has been cut at the top of the bore, I have seen plenty that needed to go to a larger bore size on the gasket due to this.
Old 09-27-2012, 02:11 AM
bww3588's Avatar
I always go by the rule of thumb of .030 larger than the cylinder bore. Of course it also depends on the chamber radius as well.
Old 09-27-2012, 12:45 PM
Bilster's Avatar
I like it. With Cometic quality, that will work fine and it's actually ideal in terms of cylinder fill contamination. The crevice created by a larger gasket allows spent gases to "hide" in the chamber, contaminating the next fill. Not a big horsepower loss but effects emissions. If you do get your vehicle checked, you gasket choice might work in your favor if you're on the border.
Old 09-27-2012, 01:00 PM
slt200mph's Avatar
Been running the 3.910 Cometic gaskets in that size bore for many years now without any problems. Go for it.
Quick Reply: Head gasket bore diameter?
