799 heads have two different size exhaust valves... WTF??
I bought some 799 heads new on eBay a couple months ago, had WCCH mill them 0.022, and I have put about 600 miles on them since. I took them off last night to swap the lifters and springs because I had some annoying lifter tapping on the driver side. On this head I noticed that two of the exhaust valves are 1.55" and two are 1.59". I haven't measured the ones on the other head yet. I also measured how far the valve stems stick out of the head and there is a 0.03" spread in the stem height.
What the heck is going on here??? Can I run it as is? This is my daily driver and was hoping to have it buttoned back up tomorrow. I don't really have time to get new heads or valves, or have machine work done. I do have a set of 5.3L heads I could pull the valves out of, I think they have 1.55 exhaust valves, but they have 105k miles on them.
This is what I get for buying heads on eBay, even though they were new
The other head has all 1.59" exhaust valves... Now I'm really confused. I'm leaning towards just using them as is. There was no obvious issues during the the first 600 miles. I may have to use some different length pushrods to get the preload correct with the varying stem heights.
that sucks, sorry to hear. Hope you put that in your feedback on eBay. To many people get burned on eBay and don't hit the seller with negative feedback. I don't think it would hurt anything running them. It wouldn't be ideal but i don't see why not. I guess maybe it could **** with the tune a little bit.
The heads had a couple other issues as well, like broken off bolts in holes. I emailed the seller, we will see what he says.
Talked to someone else at WCCH today and he said that the 1.59" are LS3 valves. I have no idea how they got in there. He said I can run them, but they don't seal as well with the head because the 45* chamfers are perfectly lined up. And, they will cause the stem height to be lower.
They are hopefully going to ship me some 1.55" valves overnight and I'll have them tomorrow.
