Comp Cam Trunnion Bolt
Old 12-09-2012, 02:22 PM
badazz81z28's Avatar
Default Comp Cam Trunnion Bolt
Does anyone know If I can buy this bolt from somewhere other than Comp?
One of my bolts there is a thread that is dik'd up and wont thread smoothly into the head. I tried to wire brush it, but same issue.
I thought I would see if I could buy it cheaper than $25 from CPG.
Old 12-09-2012, 07:01 PM
blacknyellow's Avatar
I'd just drop the $25 and never have to worry about it
Old 12-09-2012, 07:46 PM
kossuth's Avatar
If you had a decent tap and die set you might be able to fix it by running a die over it, but ultimately the poster above has the right idea if the bolt is that badly jacked up.
Quick Reply: Comp Cam Trunnion Bolt
