upgrade merry x-mas too me
Old 12-27-2012, 08:24 PM
M1SERY's Avatar
Arrow upgrade merry x-mas too me
spring upgrade
wonder if anyone is runing anything close to this set up ,if so how much hp power are u making???? just motor hp is fine.
and if cut the pistons how many thousands did you cut them or and what clearance did have???
just got my heads today, stage 2.5, 5.3 heads milled them down to 59cc, got 0.045 head gaskets, have magic 4,new ls7 lifters, comp trunions, lindly fly cutting tools , 36lbs fast injectors, puttin an 85mm maf, also got lnc-2000 launch controler its got the timing retard on it also , going to change the way i pull timing for the 175 shot i'm going to. it is stock bottom end
I know the little stuff is not that important just boasting a little just got caught up in the typing .ha ha
thanks for any input
Last edited by M1SERY; 12-27-2012 at 08:37 PM. Reason: left out needed information
Old 12-27-2012, 09:40 PM
JustAFooL's Avatar
I have a similar setup, heads are 2.5 and milled to 59, just a 224/230 cam though. I got away with just .064-.067 clearance though on intake side. I got a strong feeling you'll be cutting.. I don't have any numbers yet but I can say that the car is a torque monster with the 4k stall. Definitely good for a low 7 1/8th pass I believe.
Quick Reply: upgrade merry x-mas too me
