Can I use Manley Nextek Springs I have on an MS3?
Old 12-28-2012, 11:29 PM
01 blue ss's Avatar
Default Can I use Manley Nextek Springs I have on an MS3?
I have a set of Manley nextek springs part #221423-16 sitting on the shelf and was wondering if it would be ok to use on an MS3 cam? Her is a link to them on Summit racing.
http://www.summitracing.com/parts/man-221423-16
115 @ 1.750" installed
350 @ 1.175" open
Old 12-28-2012, 11:55 PM
soundengineer's Avatar
no... those springs are only good to 575 lift.... the ms3 is 603/609 lift
you will run into coil bind...
also, that really isnt really enough spring pressure for that cam...need more pressure for better control with the lobes the cam uses.
Old 12-29-2012, 04:51 AM
01 blue ss's Avatar
Yeah i just looked them up on Manley's site and saw the max lift. What would be a recommended spring for an MS3?
Old 12-29-2012, 11:19 AM
use the 221436's
Old 12-29-2012, 02:42 PM
01 blue ss's Avatar
I just ordered a set of Brian Tooley's .660 lift springs.
Specs are 155 lbs @ 1.780", 380 lbs @ 1.180", 400 lbs @ 1.130, coil bind @ 1.070"
Quick Reply: Can I use Manley Nextek Springs I have on an MS3?
