Replacement Heads for LM7
I have an '04 Suburban with 2 cracked heads (Castech 706s). Is the 241 head a worthwhile direct bolt-on replacement? I ask because used 241 heads are plentiful. I need to use the same truck intake and exhaust manifolds. Power increase isn't a goal. The Suburban has 159,000 miles and I don't want to purchase new 706 heads if I can save some money on something else.
It should work, but you will lose a fair bit of compression. The 241 is a 66cc chamber, where as the 5.3 heads (706&806) are 63cc chambers. It will feel real sluggish. Each the classifed adds on here, and I'd bet you can pick up a replacement set of 5.3's for less than $200.
Just to clarify ,,,,,,,,the 706's and the 862's were used on the 4.8/5.3L and the chamber volume is 61.15 cc The 862's are not Castechs and thus have'nt had cracking problems
