600 rwhp 402 anyone have a good idea for a good h/c combo?
Old 03-02-2013, 07:10 PM
Blacklightning744's Avatar
Question 600 rwhp 402 anyone have a good idea for a good h/c combo?
hey guys im goin for 600 rwhp out of a 402 on pump gas. anyone have a good combo that will achieve that? i was going to try afr 225 heads with a thunderracing stroker cam 248/254 - .615/.623 - 112 lsa. also fast 102mm intake and throttle body as well. what ya guys think? if anyone has a combo that makes this please pm me if youd be so king . im also runnin a 150 shot of nitrous but id like to get 600 without the bottle lol. any opinions would help.
thx guys,
Tom
Old 03-02-2013, 09:04 PM
garygnu's Avatar
talk to Tony Mamo at AFR ,he mite have some nice AFR heads for sale.Tony mite help you spec a cam to work with any AFR head.
Old 03-02-2013, 09:07 PM
Tainted's Avatar
Never going to happen. With the bottle sure but never 600 na
Old 03-02-2013, 09:14 PM
s346k's Avatar
it could be done, but it'll have to be a radical motor with a LOT of money in it. I'd knock your goal down about 75whp just to be realistic.
Old 03-02-2013, 09:16 PM
TheCapo's Avatar
No question...a 403cid will need a bottle to get 600 to the tire.
Old 03-02-2013, 09:24 PM
Tainted's Avatar
Even for a 416 600rwhp takes compression big cams and expensive parts.
I really dont think people realize what 600rwhp really takes and the money that gets spent. The motor alone is over the 10k mark now add in a 1000 $ clutch to handle it, $$$ for tranny and rear upgrades. Youre EASILY over 15k for the package and thats on the low end assuming you can do some work.
Old 03-02-2013, 09:47 PM
TheCapo's Avatar
I think your a little light on the $$$ and cubes if you plan on building a 600rwhp na motor.
Old 03-02-2013, 10:01 PM
Tainted's Avatar
If you already have the block n all sure. But if you had to buy a new shortblock thats an easy 5-6k now add in cam valetrain heads etc
Old 03-02-2013, 10:07 PM
djfury05's Avatar
Not gonna happen on pump gas that's for sure.. even on E85 it'd be a stretch.. going to need some very nice parts not just box stock AFR 225s and a random cam. Like posted above drop your goal about 75 hp and your maybe there on pump.
Old 03-02-2013, 10:42 PM
TheCapo's Avatar
Unfortunately to make that kind of power na your gonna need more cubes.
Here is a 450cid with nasty cam, heavily massaged all-pro heads, and full flow 3" exhaust. The goal on this build is 600 rwhp on 91 pump gas.
https://ls1tech.com/forums/generatio...s-install.html
Old 03-02-2013, 11:01 PM
senicalj4579's Avatar
600 to the wheels no. 600hp engine yes.
Take a look at TMS 645hp 427. Im looking into that myself. Around 550rwhp is more realistic.
Old 03-02-2013, 11:05 PM
djfury05's Avatar
550rwhp is a stretch as well. 515-520rwhp is a well performing 402 on pump from what I've seen on the majority side of the discussion. There are a few above average performers out there but with the parts OP is debating on using he will not be an above average performer IMO.
Old 03-02-2013, 11:08 PM
Super Hulk Smash
JakeFusion's Avatar
520-530 out of a 402 is about all you can realistically expect. 416s can hit 550-570, but still a pretty radical build. 600 is the land of 427+
Old 03-02-2013, 11:11 PM
I agree but my estimate was more along the lines of the 427 I was looking at.
Sorry OP I was being selfish thinking about my own car
Old 03-02-2013, 11:13 PM
djfury05's Avatar
Makes sense now, carry on
Old 03-02-2013, 11:22 PM
Blackbird-WS6's Avatar
This....
OP- get yourself a 427 or bigger for your goal. Plus your love the tq with the 427 over the 402. I have the setup your wanting with a custom cam and im no where near 600
Old 03-03-2013, 12:58 AM
WTR's camaro's Avatar
if all else fails and you really want that 600 boost is another way to go
Old 03-03-2013, 01:29 AM
DietCoke's Avatar
I made 602rwhp through a 4l80 but it took 429 inches, 13.7:1 compression, e85, a vacuum pump, $2400 worth of heads and a bigger cam then you want.
Old 03-03-2013, 08:28 AM
Tainted's Avatar
You can look at my build.
408
Small bore ls3 heads
Custom cam
11:5:1cr
True duals
4" intake tract
Full supporting mods
And you see im hoping for 525whp+ pat g thinks 525 should be a breeze and I can hope for more but ive got some high end parts.
Old 03-03-2013, 10:28 PM
Gregory's Avatar
You can look at all the specifics in my signature block for 550 plus at the tire. I had 250cc intake runners on the heads with 2.1" valves. I considered what it would take for 600 at the tire and my feeling is bigger 275cc plus ports, 2.160 plus intake valves, a very large camshaft, big exhaust and a big, big intake. Oh, and my numbers were on 93 octane.
My drivetrain loss was a quite accurate 14 percent as measured on the stock GTO.
Figure the NASCAR guys make 800 plus on 358 CI, so do what they do. Most of their work is on their 400 plus CFM heads, and they do wind the engines up over 8,000 RPM.
Quick Reply: 600 rwhp 402 anyone have a good idea for a good h/c combo?
