Rocker arm bolts
Old 03-29-2013, 09:59 PM
sittinlovely's Avatar
Default Rocker arm bolts
Anyone know where I can purchase a set of Comp cams rocker arm bolts that come with the trunnion upgrade kit? Thanks
Old 04-07-2013, 11:13 AM
fox12303's Avatar
They are part number 500612545 and are available at SummitRacing but are $3 each? Call them to see if they are available in a package of 16. Fastenal sells a similiar bolt item# 39592 for $.57 each.
Spec it at your local hardwre store as they may be able to order them for you. M8x1.25 45mm long 12.9 hardness socket head bolt.
Are you just looking for replacement bolts or an upgrade from stock? SummitRacing sells stock replacements SME-143005 but they are $16 for a set of 8.
Old 04-07-2013, 12:06 PM
I just need the replacement bolts. I had to call comp cams to get them. 1 dollar a peice. Thanks for the reply.
Old 12-22-2015, 07:49 AM
seawolf06's Avatar
These are now down to $0.39 each if anyone wants them. Save yourself $35 on the trunion kit and buy these separately.
Quick Reply: Rocker arm bolts
