Anything wrong with using Felpro head gasket's and bolts?
Old 03-30-2013, 11:37 AM
94Z28-MSTGKLR's Avatar
Default Anything wrong with using Felpro head gasket's and bolts?
Broke a pushrod and am about ready to go back together with it. Stock LS1 with bolt on's. Should I use the GM gaskets and bolt kit for the heads or is using the Felpro stuff just as good? I'm on a tight bugdet but I don't want to cut un-necessary coroners. If they are just as good, I'll use them and save a few bucks I don't really have. Thanks guys.
Old 03-30-2013, 11:45 AM
yelo04goat's Avatar
wondering the same thing they offer 4.135 bore gasket and i need at least that for my turbo build
Old 03-30-2013, 11:54 AM
jrpimp00's Avatar
For a stock build I would use the felpro ones, but for any FI I would get a MLS, I have the ls9 gaskets on my turbo car
Old 03-30-2013, 12:12 PM
badazz81z28's Avatar
I agree for OEM application, nothing wrong with Felpro. IMHO I would get the GM MLS gaskets, they are not that much more than Felpro if at all.
Old 03-30-2013, 12:15 PM
yelo04goat's Avatar
fel pro makes a mls gasket and ls9 gaskets wont work with my afr heads the require a 4.135 gasket
Old 03-30-2013, 12:36 PM
Well after looking at the GM mls gaskets they are only a few dollars more than the felpro's so I guess I'll stick with the GM stuff.
Quick Reply: Anything wrong with using Felpro head gasket's and bolts?
