Cracked valve stem?
Old 04-03-2013, 04:41 PM
Horsepwraddict's Avatar
Default Cracked valve stem?
I was putting the heads together for the 5.3 in my regal today and after I had cleaned up the valves to put them back in I noticed one was cracked. It was a hairline crack all the way around the stem up by the tip, Above the retainer groove and below the hardened tip. Now I thought it was just one, so I looked back through the other head I just finished assembling and about 50% of the valves were this way. This is a 60k mile 5.3 that was running before it was pulled apart.
Now for the kicker. I have a blown up 4.8 in the shop from a job I did at work, out of curiosity I yanked a valve cover and checked it out....same thing.
Has anyone seen anything like this? I will try to grab a picture tomorrow.
Old 04-04-2013, 03:43 AM
vettenuts's Avatar
Yes, that is normal. I am assuming it is only the exhaust valves. It's part of the valve assembly process due to the welded on hardened tip.
Old 04-04-2013, 03:58 AM
well that's good to hear, I cant believe I have never noticed before. I work on these things every day.
I was about to pull the valve covers off my pickup today and check them out too.
Old 04-06-2013, 09:02 PM
chrisfrost's Avatar
Ya , I saw that also when customizing My heads but after I saw it was all of the exhaust 1's I figured it had to be normal ,,,,,,,,,,,,,I have 2 pr of heads I saw it with .
Old 04-08-2013, 04:44 AM
vettenuts's Avatar
You're not alone, I almost crapped myself when I saw it for the first time
Old 05-31-2015, 08:55 PM
Blue Knight's Avatar
Sorry for the old bump but thanks for posting this.....found some of these this evening.
Quick Reply: Cracked valve stem?
