some FAST 102 Questions for the LS1
First off anyone know the PN for the 8 gaskets i need for the intake ? 2nd i have http://www.summitracing.com/parts/pf...1/media/images
can i make this work on the LSX intake? ... lost the mounting brackets for the rails so i still need to find those also or buy new ones. Last Question what type of fuel injectors do i need LS1 Ls2? high or low impedance?Thanks for any help!
Super Hulk Smash
You can run LS1 injectors and adapters with the LS2 rails. Or just run the LS2 injectors. If you run LS1, make sure they are "skinny" type or else it'll be a bitch to fit them.
PN for the gaskets is #146203-8. The older FAST90/92 gaskets will work as well, but you have to cut an extra little tab off for it to work with the 102.
Here's a good FAST 102 thread if you haven't seen it.
https://ls1tech.com/forums/generatio...02-thread.html
For the gaskets I bought fel pro's from advance for 20ish, and i didnt cut the tab since the 102 has the slot for it and they went on snug. For the price of those rails why not just run a ls2 rail. I'm running an ls2 rail with cbm spacers that were 14 bucks on my ls1 injectors.
