Clutch issues?
Clutch issues?
Picked up my car a month ago bone stock 02 T/A with 63xxx miles on it since then I put full bolts on on it and have run some other cars. I'm having some problems with more clutch feel than it actually slipping. If I do three roll races with another car the first pull I can bang gears and the clutch feel is great. On the second run clutch feel becomes sh*t and the pedal doesn't want to come back all the way out. By the third run its a little worse and will slip sometimes between 3rd and 4th gear when I slam it. If I pump my clutch 10 to 20 times clutch pedal feel becomes normal again any ideas or thoughts its really starting to annoy me thanks!
Mine did the same thing. I put a good clutch in it ( monster level 2) and haven't had a problem since. I changed the slave cylinder with a new one. Still useing the master that was in it. It was replaced about 10k before I did it all. I saw no point in replacing it until I decide to drop the coin on a tick or something better. Ever since the new clutch I haven't had a issue so I'm runing it
