LM7 with LS6 Intake/cam Swap #s
I know a lot of guys on here have been interested in this swap and what numbers this will produce. (I was one of them) Well here you go guys.
This is the combo;
2004 LM7 from a Tahoe
4.8L LS flat top Speed Pro pistons
stock bore/stroke
stock bottom end (arp rod bolts)
LS6 intake/injectors/tb
2002+ LS6 cam 204/218 int/exh @ 0.05" duration 0.551" / 0.547" int/exh lift
Edelbrock long tube headers
dual 2 1/2" mandrel bent exhaust
LS2 timing chain
ported LS6 oil pump
Rebuilt 4L60E Corvette spec (beast sunshell, servos etc)
Corvette converter
3.42:1 rear end gears in stock GM 10-bolt
This combo made 311whp and 297wtq in 2nd gear (if done in third add about 15 to each)
This is the combo;
stock bore/stroke
LS2 timing chain
ported LS6 oil pump
Corvette converter
