Cam and 1.8 Rocker Arm question
I'm gonna go with the GM ASA cam for my 02 Z28. It will be pretty close to a year before I can get everything I need and get the time off to do the work. So I was wondering if by some chance I found a good deal on some 1.8 rocker arms, would it be worth it to use those compared to 1.7. I understand that it would be cheaper to just get a cam with a higher lift but I figured if I found a good deal it might be worth it. Also, would it even be safe to run the 1.8 rocker arms?
