stuck valve spring?
stuck valve spring?
i have a set of 862 heads im using,idk how long they have set around till i got them but after i tighten my rocker down the spring will stick the pop out all of a sudden,i lubed it up and it pretty much stopped,but still dos it every now and again,anyone had this issue,and since i havent started my car since the head swap would it fix it after oil has circulated through the motor after run time?
