Basic Fuel Line question
Old 05-29-2013, 10:41 PM
mbobek88's Avatar
Default Basic Fuel Line question
Hi. I'm installing a new aftermarket tank with internal pump into a '64 Malibu SS. Pump has both fuel and return line outlets. My LS-1 does not have a return line on the rail. Questions: Should i simply plug the return line at the tank, run the fuel through the oringinal line to the fuel rail, and hook the vent line up from the via the original set up? I was planning to install a filter just after the tank. Assuming the stock regulator on the fuel rail will suffice? Any other considerations/suggestions? Thanks a lot from a rookie!
Old 05-30-2013, 06:40 AM
Old Geezer's Avatar
Wrong forum........
This has been discussed in the fueling forum.... Just recently.
Old 05-30-2013, 06:57 AM
LS1MCSS's Avatar
That's not a regulator on the rail. You need a regulator inline and a return line to the tank.
Quick Reply: Basic Fuel Line question
