How bad is it?
How bad is it?
Just got around to working on my 98 z28 that the guy I bought it from said it had a blow headed gasket well I removed the valve covers and this is what I found
My eyes may be going bad but is that water i see on the top of the retainers and in the rockers? That sucks... Send em out to get ported or get something better. Is it only on the one side? Or have you had a chance to pull the other side yet?
I kinda figured they would be the same... you would want to refresh them both anyways. Send em out to get machined then... put some nice stuff in them. Or maybe its time to upgrade to something better than LS1 heads???
If it was caught in a timely manner you can disassemble, clean, and with a dino oil change every 300 miles be just as good as new - assuming the head is not damaged or warped. The detergents will make quick work of a hot mess in no time.
Honestly though if you suspect the previous owner ran it in that condition for any long length of time i would pull both heads and check the bottom end. antifreeze has terrible lubrication properties
He didn't run it after the gasket blew. The car sat for about 5 yrs. I did start it before I bought it though and I'm think I'm going to change the heads completely because I found a stock set local for $50.
Wow would have been nice to know that in the first post... I kinda figured you had bought it recently and drove it home and took the valve covers off. 5 years is a long time for it to be sitting there
That's MISTER MODERATOR
Do an oil change using cheap light weight oil-like 0W-30. Use a decent filter. Run the engine until it's hot. Cool down repeat.
This will remove much of the contaminated oil (milkshake) from the crankcase.
Assuming through all this, the bottom end (crank, rods, pistons) make no knocking or banging noise, pull the heads and send them out to be re-refreshed.
New head gaskets, new head bolts, make it all nice and you'll be ready to cruise.
WARNING: Head and head bolt installation involves some very specific instructions. Doing it wrong and you'll crack the engine block.
It looks to me like the thing was barely maintained in the first place. A lot of sludge from hardly ever changing the oil.
Why put new heads on what is likely a shot short block?
It's your money, but I would find a replacement engine. That's cheaper than a rebuild, which is likely needed here.
Ron
Ron
In all honesty, they probably will not do that. Any competent mechanic can do it, just finding one willing to just torque the head. Theres too much liability and potential for things to go wrong to take the risk.
I lined up a timing belt for a guy to help him out (no charge mind you) and he went out immediately and beat the **** out of the car and broke the cam gear. He wanted me to buy him a motor because it had to be something I did wrong.
Instances like that are why most mechanics wont do simple jobs to help people.
