ls2 rod upgrade mahle piston
Old 06-16-2013, 09:21 PM
Go5.3tt06's Avatar
Default ls2 rod upgrade mahle piston
I have a questions for you. If Im going to do LS6 3.898 block since I have ls2 rod with .945 floating I think. And want run mahle flat top piston. Is it bad idea to use stock ls2 rods? What compressor ratio would be for that and run 243 heads. Let me know what do your opinion. Many thanks.
Quick Reply: ls2 rod upgrade mahle piston
