LQ9 vs. LS1 Rotating Assembly Questions
I had a few questions between the 2 rotating assemblies because I have alot of parts I was trying to sell to see what would work with what.
I know LS1's and LQ9's have the same crank. But are the rods the same? By that I mean can I use stock LQ9 Rods for Stock LS1 pistons? I know the bore is a different size but if the stroke is the same should the rods be intechangable between the 2 motors? Thanks in advance for the info....
