Rocker Arms for 5.3 heads
Im putting 5.3 heads cast 706 when i do my cam install on my 98' TA
Im using a mild cam
COMP Grind: XR275HR
I grabed all the parts i could such as the lifters, rods, springs, retainers, locators, ect.
Only thing i have not grabbed was rockers. Reason being is im building the heads with all new valve train
Im using a mild cam
COMP Grind: XR275HR
I would keep the stock 1.7 ratio although there are aftermarket rockers that take the rato up 1.8. The higher ratio should not be required if you have chosen the right cam (speced on 1.7 ratio).
https://ls1tech.com/forums/generatio...igger-cam.html
https://ls1tech.com/forums/generatio...8-rockers.html
