rod bearing
Old 07-13-2013, 08:46 PM
Cstan14's Avatar
Default rod bearing
Whats the easiest way to change rod bearings in my 99 z28?? its my daily driver need to get on the road hopefully before tuesday if possible. let me know please! thanks
Old 07-13-2013, 09:23 PM
chrisfrost's Avatar
I hate to be the bearer of bad news but the only way to change You're rod bearings and have as close to 100% certainty as You can that it will last longer than the break in period is to remove the engine from the vehicle and if You;re fairly mechanically inclined and confident, then get a book on rebuilding the LS gen 3 & 4 chevy small blocks and do it right because if You try and install new bearings with engine in the car not only will You be frustrated at how hard it will be but very little chance it will work longer than it takes to barely break in the engine. Or probably You're best bet would be to get a junk yard truck engine like a 5.3L or a 6.0L ,,,,,,,etc
Quick Reply: rod bearing
