no rpm gauge after head/cam swap
Ok started my car for the first time this evening. runs and idles on its own no problem. everything sounds good and is working as it should. except for the rpm gauge. it isn't showing any rpm. So i think that it is after the computer since it wouldn't run as well if it was not reading any rpm.. i could be wrong though. Also my traction control light is on and the button does not do anything (related?)
Here is the run down of the car:
pulled the motor to do this
factory 243 heads
sns cam
fast 92/92
brian tooley springs
ls7 lifters (they are silent!!!!)
also did tick mc, monster stage 2, and underdrive pulley
here is a video too https://www.facebook.com/photo.php?v...65751734550242
factory 243 heads
sns cam
fast 92/92
This thread might help you.
https://ls1tech.com/forums/generation-iv-internal-engine/336953-rpm-gauge-not-working-sdpc-402-a.html
Thank you^ i am throwing the same code he was p0342 cmp voltage low. Im going to take the intake off tomorrow to check it out. hopefully its just the connectors or something easy. I wanna drive this!
