Anyone running this cam?
Old 08-21-2013, 11:27 AM
bwilde86's Avatar
Default Anyone running this cam?
http://www.lingenfelter.com/mm5/merc...=#.UhTmN8u9KSO
I've searched on here and people are putting different numbers on it. Am I just looking at it wrong? New design on the cam?
https://ls1tech.com/forums/new-ls1-o...r-gt-12-a.html
Here is an example. Not too knowledgable on cams. Any info is appreciated.
Old 08-21-2013, 12:22 PM
Russ K's Avatar
That is a Comp Cam with LSL lobes. With 1* overlap there will be no surging/bucking at light throttle/low rpm. And with 115* lsa, you will have great top end power.
That post from 2012 is totally wrong.
Russ Kemp
Old 08-21-2013, 12:59 PM
bwilde86's Avatar
OK I found a few other threads with identical numbers of the one from 2012 on different forums. So didn't know if ligenfelter redid the cam and reused "gt12"
Quick Reply: Anyone running this cam?
