ls6 intake & 243 heads on 98 ls1 pcv lines not working
Old 08-22-2013, 09:14 AM
ryangtp89's Avatar
Default ls6 intake & 243 heads on 98 ls1 pcv lines not working
As the title states. Don't want to get a ls6 valley cover the motor is already buttoned up. Is there write ups on custom made lines to fit ?
Old 08-22-2013, 09:44 AM
wildcamaro's Avatar
I had the same issue with my 98...Ill have to take a look when I get off work and see how I routed it to take advantage of the ls6 set up, I didn't want a catch can or ls6 valley cover either, I was going for stock appearance...easier to win bets that way lol
Old 08-22-2013, 10:27 AM
98ws6blk's Avatar
I have the same setup but with 799 heads, same same. You basically just have to rig up your own vacuum lines. Pull 1 line from the driver side valve cover (in the back). Pull 1 line from the passenger side valve cover (in the back). Do a t-fitting for both of those and run a hose to the PVC line (with the valve).
Old 08-22-2013, 11:12 AM
wildcamaro's Avatar
Yea that sounds about the same as what I did
Old 08-22-2013, 11:38 AM
ryangtp89's Avatar
OK good that sounds easy enough. What size t fitting do I need also what size hose ?? anything else ?
Old 08-22-2013, 12:27 PM
98ws6blk's Avatar
I can't remember the size...just go to the parts store with your PCV line and the grommet from your driver size valve cover and I believe you'll be able to figure out how to to go A to B. The hole in the grommet is big, so you'll likely have to put another hose inside it to step down to the other hose sizes....hope that makes sense : )
Old 08-22-2013, 01:29 PM
ryangtp89's Avatar
I'll try that
Quick Reply: ls6 intake & 243 heads on 98 ls1 pcv lines not working
