Milled ls3/l92 guys inside please.
Just curious what size pushrods and cam most of you are running, head gasket thickness?
Im using milled .030 821ported/polished heads, gasket thickness of. 042 (stock g8) gasket. And a trex cam, so. 608/.612 lift. I measured my pushrods at 7.325. But, i accidentally orderes 7.300". Was tild to install a couple and check anyway sonce when we measured. My lifters werent preloaded. So i did. And they seem and ride on the valve stem fine. Just want a general consensus if im ok. Or am now too short and should get the 7.325. Thanks in advance.
