#10 lifter tray failure, any truth to this?
I read somewhere that the ls1 lifter trays with a 10 on them have a higher failure rate of letting lifters rotate. I just had it happen to me the other day, 108k stock bottom end, tr224 cam .563 lift. 918 springs, unknown mileage I just bought it that way a few months ago. Actually had a set of new springs sitting in the garage but never got around to changing them.
Anyway, noticed a ticking one day on the highway. It kept getting worse and 500 miles later I have no oil pressure. The lifters for the intake side on 1 and 3 both turned and ate up the cam, then the metal bits jammed the oil pump pressure relief valve. they were in a #10 tray. None of the other trays were 10, and they were all fine. Random chance or what?
Yes, you don't hear much about it now though. There are old threads where this was documented. Some of the #10 trays had a slight angle such that the roller didn't run true on the cam lobe and ultimately this caused the roller to fail.
I ditched my #10's the first time I had the motor apart.
