How much can lm7 rev?
Old 09-01-2013, 11:12 AM
Turboswede's Avatar
Default How much can lm7 rev?
Hi
Im swapping in an lm7 in car and wonder how much would be ok to rev it?
Im change the cam but don't know yet to what. I will also use Comp Dual 675 spring/Comp Pushrods.
I have only worked with straight 6 before.
Would 6500 rpm be to much?
Old 09-01-2013, 11:51 AM
wildcamaro's Avatar
Heck no...swap out the rod bolts and spin to 7000rpm, tons of guys doing it, even on stock rod bolts...depends on the year of the motor you might have the newer design rod bolts, but aftermarket ones will be superior to any stock rod bolt...only thing is you have to get the rods resized to use the aftermarket ones
Old 09-01-2013, 12:41 PM
Slimsilverado's Avatar
I spun my stock bottom end 5.3 6500 all day long with no issues
Quick Reply: How much can lm7 rev?
