ls6
Old 09-23-2013, 02:13 PM
my406cid's Avatar
Default ls6
Lucked up and gota 02 ls6 cam for free. What would this cam in a 6.0 with l92 heads and a 11.0 comp with 1.85 rockers make With a ported l92 intake? Curious I am
Old 09-23-2013, 03:01 PM
sabastian458's Avatar
That cam doesn't use those heads/intake to its potential. Don't expect a whole lot from it. I'd say 10-20ish over what a stock 6.0 cam will do, if that much, depending on which 6.0 you have. you'd need to calculate for the added lift & duration from the 1.85 ratio. Also you need to check PTV clearances.
99-00 Lq4- 191/190 .457/.466 114
01- up lq4/9- 196/207 .467/.479 116
05-06 Ls2- 207/217 .525/.525 116
01 ls6- 204/211 .525/.525 116
02-04 ls6- 207/218 .551/.547 117.5
Quick Reply: ls6
