Mobil 1.. 5-30 oil ???
LS1s do tend to quiet down with oils containing anti-wear additive levels in the 1200ppm range, as the API spec existed at the time these engines were built. The current SN spec reduced these (zinc & phosphorous) substantially, which is fine for stock engines but if you've upgraded to stiffer valvesprings the engine can use the extra extreme pressure additives.
Mine liked Mobil-1 High Mileage 5W-30 (older SL spec and higher zinc/phos levels) but something seemed to have changed in 2012 and the tick returned. I then went to RedLine 5W-30 and it was gone in a few dozen miles.
My neighbor's LS6 had the same issue with stock valvetrain, he went with Shell Rotella T6 5W-40 and the tick cleared first drive out of the garage.
I've had luck with the Mobil 0W40...european blend; Some claim that this has higher zinc levels like the high mileage branded oils...I just know that it
quiets my valvetrain back to stock sewing machine sounds..cam is .595/.598
It lets me know when it's dirty or needs a change by getting louder...usually
2500-3000 miles
2500-3000 miles
