347ci texas-speed rotating assembly
Hi
merry Christmas to you all
I have one question about 347 forged :
Weisco pistons
compstar rods
callies compstar cranck
The rotating assembly balanced
by texas-speed
I get the order but I didn't see any match numbers between rods & pistons
Should I install any piston with any rod in any room
or what ???
Thanx alot
Weisco pistons
compstar rods
by texas-speed
or what ???
Thanx alot
I know when i've had rotating assemblies balanced, rods are mounted on the pistons and each piston was marked as to which cylinder it was balanced to. That doesn't seem right to me what they did. Are you supposed to guess? Yikes, i thought about ordering a rotating kit from them, not if that's how they do things.
I wouldn't install any of that if it were me until they can verify if they even balanced it or not.
actually the rotating is balanced and I have the balanced sheet from texas shop
it comes with the order and the results before and after balanced are very great and I am happy with it
but the thing I cannot figure why it's not numbering??
If any one had same my cause pleas help.......
thanx for replying
The rods are most likely the same on rotating and reciprocating ends also.
So what if the puzzle pieces are not numbered. Shops usually only number
the pistons when specifically honing cylinders to the exact piston size. IIWY
I'd ask TSP if they pin fit the pistons/rods. If not then have a local shop do
them up quick. They should be sized from .0004" out to .0008" before being
put together. Lastly make sure the bearing notch side of the rods face the
oil pan skirt side of the block.
